So from what I've read, the black key limits the horsepower to 500 by maxing out the rpms at 4000.
On a manual shift car, does this mean the fuel cutoff will engage at 4000 if you don't shift before then?
I'm not going to use the black key...moot point
Discussion Starter · #4 ·
The car has an electronic throttle so it could just back off as the RPMs approach 4000. On a side note I though valet mode limited RPMs not the black key.
maybe you are right....I assumed that would be the way to limit the hp...by limiting the rpms?
