I'm upgrading to Led headlights on my '15 R/T with oem halogens. While I was replacing the passenger side bulb, the pigtail connector fell off and left the pwr wires exposed and touching. Pwr switch was and since then I have no pwr to the connector. I've searched for a fuse but I don't have fuse #15 & 16. Anyone have an idea where the fuse would be?
Thnx
There are two fuse boxes, one in the engine bay and the other in the trunk next to the battery.
Sent from my SM-G975U using Tapatalk
Yes I saw the one in the trunk but didnt see anything that would be a fuse for the headlights.
the models built with OEM HID headlights have a Left / Right fuse in front power module (#15 / #16)
- there rear power module has two 40A (green) fuses #6 / #7 denoted as Exterior Lighting
Ok I figured out the trick. Disconnected the negative terminal for a few seconds and waited a few min. Headlight came right back on. Thnx for the info!
