1 - 19 of 19 Posts
Hi. I'm a new member and this question has probably been ask before so bear with me please. I have a 2019 R/T 5.7 with stock goodyear 245/45/20. I just replaced the rear tires with Nitto 275/40/20 Motivo. The original plan was to run the stock 245/45/20 on the front but now they look too small. I like the staggered look of fat tires on the rear and narrower on the front. My point is that I'm unsure weather to run 255/45/20 or 255/40/20 on the front ? Keep in mind that at some point down the line I may want to lower the car with the Mopar springs. Thank You !
That is a nice setup. I did the 275/40/20 on the rear with the 245/45/20 on the front.
976515
Do you have any other photo's that you can post of the front wheels ?
Looks great ! No rubbing or handling issues on the front ?
No rubbing or handling issues at all. Mopar lowing kit from Summit Racing also installed. I actually took out Eibach springs that were lower because the shocks were the wrong size when I purchased the vehicle.
976519
976520
Yes, Installed on the factory wheels.
Can you please keep us posted on how the 275s on 8 inch wheels works out? I'm sure it will look great, but I'm concerned about premature wear and whether or not the meatier tires improve performance. I have heard that slightly underinflating the tires can help with both of these concerns.
255 is as wide as you should go on 8" wheels, just sayin'
Reactions: 72/340
I also had bushings installed to align the rear end and prevent negative camber.
"whether" not "weather"
Discussion Starter #13
Hi. I'm a new member and this question has probably been ask before so bear with me please. I have a 2019 R/T 5.7 with stock goodyear 245/45/20. I just replaced the rear tires with Nitto 275/45/20 Motivo. The original plan was to run the stock 245/45/20 on the front but now they look too small. I like the staggered look of fat tires on the rear and narrower on the front. My point is that I'm unsure weather to run 255/45/20 or 255/40/20 on the front ? Keep in mind that at some point down the line I may want to lower the car with the Mopar springs. Thank You !
I put 275/40/20 Pzero tires on the back of my 2010 FF R/T stock rims 3 years ago and have not had any issues running that setup up to this point, everything is stock have not changed anything with the suspension.
Reactions: Rg21044
Discussion Starter #15
My question regarded whether to run 275/40/20 or 275/45/20 on the front, but thank you for a reply.
Guess I missed that
255/45/20 would be a better fit. It's circumference is only 1% more than 245/45/20 so it shouldn't cause speedo issues while a 255/40/20 is almost 3% smaller.
Width-wise, it's only .4 inches wider so I'm not sure if you'll see that staggered look you're looking for.
You can use this site to compare sizes:
You want to keep the tire diameters as close as possible so you won't affect the accuracy of your speedometer.
If you have 275/40-20s on the rear (28.7" diameter), you need 245/45-20s on the front (28.7" diameter). The 255/40-20 tire has a smaller 28" diameter.
I have 315/35-20 on the rear and 245/45-20 on the front. The rear rims are 10.5x20 with a +25mm offset and I run a .25" spacer.
1 - 19 of 19 Posts
