1 - 20 of 56 Posts
R1 Concepts| Carbon Alloy Geomet Rotors!
We're happy to introduce to you all our new Carbon Alloy Geomet rotors! Manufactured for European and heavy vehicles, our High Carbon iron formulations (Molybdenum, Chromium, and Carbon) enhances noise dampening characteristics, while providing high strength, and increased thermal conductivity compared to standard discs, which increases durability.
Each rotor is engineered to match the OE vane configuration, including OE split-core technology to ensure proper and maximum heat dissipation. Additionally, all cores are dipped with a specifically formulated paint in order to provide a smoother finish inside the vane structure. The smooth finish will improve air flow as well as reduce the amount of machining require in or to properly balance the finished rotor during the mill-balancing process.
Fine-Turned
Next, the castings are sent to our state of the art machining facilities, where each rotor is machined to the tightest tolerances available in the market today. We can guarantee specifications of .010mm disc thickness variation (DTV) and .050mm maximum lateral runout. Though in practice, we regularly achieve .007mm DTV and .025mm maximum lateral runout. Then, the rotors are fine-turned to a maximum of 1.6 RMS. The objective of these strict tolerances is to create the smoothest possible finish, which improves initial break-in due to the increased contact between the pad and the rotor.
After all of the machining processes are completed, each rotor passes a 100% electronic inspection station that measures over 20 attributes to ensure that each rotor meets OE specifications. This further guarantees that each and every rotor delivered to you is trouble free.
GEOMET Finish- The Superior Corrosion Protection
Finally, we apply a genuine GEOMET Finish throughout the entire part, which promises to deliver superior corrosion protection. The GEOMET coating is processed dry, shipped dry, and ready to install without any additional preparation. An average brake job takes 1.25-2.5 hours per axle. Without the need to clean an oil covered rotor, this same a tremendous amount of time and money during the installation process.
  • Superior Corrosion Protection- Provides excellent cyclic corrosion performance when tested to automotive manufacture's test methods incorporating heat, salt spray (withstands 400 hours), and humidity (SAE J2334, GMW 14872, Ford CEPT: 00.00-L-467, Asian CCT).
  • Environmentally friendly, this meets the following regulations: Environmental Protection Agency (EPA), Chrysler CS-9003, General Motors GMW 3059, Ford WSS-M99P9999-A1 (Hex 9), the EU Directives on End of Life Vehicles (ELV) and Electrical Equipment (RoHS).
HELLTCAT/SRT 392
FRONT 2-PIECE CARBON ALLOY SLOTTED GEOMET ROTORS
TOTAL: $880/PAIR SHIPPED
BRAKE KIT
FT/RR CARBON ALLOY SLOTTED GEOMET ROTORS
FT/RR R1 OPTIMIUM CERAMIC PADS
TOTAL: $240 SHIPPED (V6)
TOTAL: $275 SHIPPED (R/T & SXT W/ PERFORMANCE BRAKES)
FT/RR CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS
TOTAL: $260 SHIPPED (V6)
TOTAL: $295 SHIPPED (R/T & SXT W/ PERFORMANCE BRAKES)
ROTORS
TOTAL: $185 SHIPPED (V6)
TOTAL: $205 SHIPPED (R/T & SXT W/ PERFORMANCE BRAKES)
TOTAL: $340 SHIPPED (SRT8)
TOTAL: $205 SHIPPED (V6)
TOTAL: $225 SHIPPED (R/T & SXT W/ PERFORMANCE BRAKES
BRAKE PADS
R1 OPTIMUM CERAMIC PADS
R1 PREMIUM SEMI-METALLIC PADS
R1 PERFORMANCE SPORT PADS
CALIPER PAINT
G2 CALIPER PAINT KIT: $40 SHIPPED
Contact Info
Kevin C.
Sales Rep
[email protected]
888-712-6623 ext. 7022
2015 challenger R/T
Have anything for drag racing small brake kits for the rears. So we can fit 15" wheels on the rear
I apologize for the late reply back. Unfortunately we do not. All of the brakes we offer are all OEM spec and direct fit or you can upgrade to our R1 Big Brake Kit as well. However for the R1 BBK, we would not have anything to fit under a 15" wheel.
1 - 20 of 56 Posts
