21 - 27 of 27 Posts
Discussion Starter #21
Hey guys, problem solved!
Turns out the ETCS was reading way out of range and needed to be replaced. Glad it was a simple fix.
You mean the engine coolant temp sensor was defective? I don't see how that would cause your cooling system to overheat and coolant to boil out of the reservoir? If anything, it would kick the fans on earlier. I am confused.
Discussion Starter #23
Apparently the temp sensor was not telling the fan to kick on until it was way over the normal temp range.
Ah, OK so it was registering lower temps when they were actually higher. Makes sense. For some reason I thought it was the other way around.
Discussion Starter #25
I’ll speak to the mechanic so I can give a better description of what was happening.
Unless it is a reservoir/overflow tank. My liberty has 2 separate cambers, one is pressured and the other is not and has a hose going from the reservoir tank neck into it. It also has a vent near the firewall side that sits at a high point so if the coolant expands when hot it goes into the overflow side and reclaimed when coolant gets cold.
I think the tank on the earlier models (2009) looked like this
Ran into this while reading one of the FCA work books. There is even a section about OAT and HOAT coolant explaining the differences.
979649
21 - 27 of 27 Posts
