Ohio-Speed is proud to announce we are adding the Razors Edge Suspension Line to our I WISH IT WAS SPRING SALE!
Great pricing plus FREE S/H!
Razors Edge Front Adjustable Sway Bar Links 306-5016 (shown)
Razors Edge Rear Adjustable Control Arms 306-UCAR
Razors Edge Standard 2 Point Rear Strut Tower Brace Moly- Alloy 306-5013
Razors Edge 6-Speed Transmission Cross-member 306-STCM
Razors Edge Arched 2 Point Rear Strut Tower Brace 306-5013A
Razors Edge Automatic Transmisson Cross Member 306-ATCM
Razors Edge Challenger/LX Front Lightweight Bumper Support 306-LWBF
Razors Edge Cornering Force Suspension Endlink Kit 306-2002
Razors Edge Mopar LX Rear Adjustable Sway Bar Endlink Kit 306-5017
Razors Edge Rear Tension Arm 306-RTA
Razors Edge Strut Tower Brace for Supercharged Applications 306-5011M
Razors Edge Arched 4pt Rear Strut Tower Brace 306-5012A
Razors Edge Front Shock Tower Brace 306-5011
Razors Edge Subframe Connectors 306-5025 Razors Edge Rear Lightweight Bumper Support 306-LWBR
Razors Edge 5.7L-6.1L Hemi Solid Motor Mounts 306-5761MM
Razors Edge 6.4L Hemi Solid Motor Mount Kit 306-64MM
Razors Edge Anti-Roll Kit (Front & Rear Anti-Swaybar) 2873320
Razors Edge Bump Steer Kit (pair) 306-5030
Razors Edge Close Out Panels 306-COP
Razors Edge Front Adjustable Control Arms (pair) 306-UCAF
Razors Edge K-Member 306-5010
Razors Edge Standard 4 Point Rear Strut Tower Brace 306-5012
Razors Edge has now come up with another great suspension upgrades for your Challenger, the most overlooked component is the sway bar link.
This simple component attaches to the suspension and promotes stabilizing or "planing-out" the vehicle in a turn.
Did you know that the simplicity of this link can hurt your car's performance?
We have created a system replacing the fixed-length pogo stick configurations.
The Razors Edge Adjustable Sway-Bar Link System provides the ability to easily adjust or tune the sway bar as part of the suspension system.
The stabilizer-bar has been overlooked as a tunable component in the production-based suspension system due to the lack of an adjustable link.
The OEMs recognize that it is important to have a sway bar for cornering stability.
It is installed in the suspension system and sent down the assembly line.
From personal investigations, the sway bar with fixed length links can induce a load into any two cross-corners of your vehicle.
The ability to neutralize the sway bar in your suspension system is a great advantage to baseline, balance, and refines your vehicle's handling characteristics.
The Razors Edge Adjustable Sway-Bar System in not limited to road race cars.
Anyone that has taken the time to upgrade their street car's suspension should consider this product.
Once again, knowing the influence of your sway bar on your suspension is as important on the street as it is on the track.
Drag racers may want to include this system as a way to preload the right rear of their vehicles
PM FOR OUR LOWEST PRICE AVAILABLE!
Discussion Starter · #2 · (Edited)
These Adjustable Rear Control arms presented quite a design challenge for REM.
Other solutions in the market offer standard threaded adjustments, but we knew the reason these lack durability is that the threaded portions are not loaded axially.
As such, we set out to incorporate some technology developed while working with a GRAND-AM racing team on their LC race car - adjustment tabs.
The arms are precision machined from 6061 billet aluminum and the tabs are laser-cut from steel plate for an exact fit.
By changing out the tabs with different offsets, you can tune the alignment of your vehicle to suit your needs whether you're trying to increase ore reduce camber.
The arms are designed to occupy the same space the OEM arms to ensure they do not interfere with any aftermarket shocks/coilovers, etc.
Like our Billet Tension Arms, these also feature 90 durometer Polyurethane bushings that ensure long, slop-free life from the parts even under the most punishing conditions.
Discussion Starter · #3 · (Edited)
This braces features the benefit of super tough 4130N Chrome-moly alloy steel.
This makes them more than twice as strong without adding any additional weight.
If you're looking for true race car performance and the best strength-to-weight ratio this is the part for you!
Discussion Starter · #4 · (Edited)
Razors Edge New 4130 Chro-moly 6-speed transmission cross member for the Dodge Challenger.
Designed to be stronger than stock yet still weighs 50% less at 3lbs compared to 6lbs.
Allows more working room.
The Razors Edge cross member comes powder coated in our customary texture black for a tough long lasting finish and includes new bolts.
Installation is simple and takes approximately 10 minutes.
PM FOR OUR LOW PRICE WITH FREE S/H!
Discussion Starter · #5 · (Edited)
Following the success of our two point rear strut tower bar, Razors Edge has once again engineered what you the customer has asked for.
Built from 4130 Chro-moly tubing, our new arched two point provides all of the chassis stiffening qualities you have come to expect along with the added trunk space you need.
Powder coated in our customary texture black finish for a durable long lasting finish.
Discussion Starter · #6 ·
Razors Edge Cornering Force Suspension Systems include everything needed to build an awesome handling car with excellent street manners.
Razors Edge designed these parts using Computer Aided Design (CAD) software and the experience gained from years at the racetrack.
Each stage provides an outstanding improvement in performance and a well balanced car in an affordable package.
Razors Edge Endlink kit suspension builds a base for any future modifications by addressing three essential elements needed for performance.
Benefits
Front Adjustable Endlink kit maximize your swaybars and adjust the suspension to suit your needs
Rear Adjustable Endlink kit maximize your swaybars and adjust the suspension to suit your needs
Front Bumpsteer kit corrects bump steer in the front suspension.
Directly replaced outer tie rod end.
Tapered shaft design for hassle free installation that requires no drilling of the spindle.
Discussion Starter · #7 ·
These Razors Edge Adjustable Endlinks directly replace the factory non-adjustable endlinks.
This provides you with ability to adjust the swaybar preload and tune the Rear swaybar.
Used for the ultimate in handling setups.
These pieces use chrome moly steel adjustment tubes which are lighter and twice as strong as competing designs.
Strong reliable ball joint ends allow for greater turning radius than competing setups and do not produce noise making them perfect for street use.
Benefits
Allows For Fine Tuning of Front Suspension
Stronger Than Factory Endlinks
Adjustability of Rear Sway Bar for Drag Racing & Road Racing Applications
Chrome Moly Lightweight Adjustment Tube
40% Stronger Balljoint Than Competing Endlinks
Great Upgrade For All Car Stock or Modified
Comes as a Pair
Discussion Starter · #8 ·
These replacement tension arms are machined from 6061 T6 billet aluminum and have been fully FEA (Finite Element Analysis) tested, and have shown to be more than twice the strength of the stock steel or cast aluminum OE part.
One end features bushings that are 85 durometer providing less deflection and distortion.
The other bushing is a FRB (fiber reinforced bushing), tested to over 60,000 psi.
This combination provides for an extremely strong part with virtually no noise and harmonics.
These tension arms are critical in keeping the rear stable and preventing oscillation.
