1 - 10 of 10 Posts
You know that Posi (short for Positraction) is a Chevy/GM term right?
For Chrysler, it would be Sure Grip. ;)
Discussion Starter · #7 ·
No I did not know that and am quite embarrassed at this point. This is my first vehicle from Chrysler/dodge. Have had chevys before. Regardless question still stands. Reason I ask is because i smoked the tires on my 392 a little but only 1 tire left rubber on pavement
Hey Chef, don't feel embarrassed. I assume your car is a 392 SRT Challenger? If so, the one tire burn is not normal. Try the burn (good one) again. If you still have only one tire leaving rubber, have it checked out.
To know for sure, jack up the rear of the car with the trans in neutral and rotate one rear tire. Both will rotate in the same direction if it has a properly functioning limited slip rear.
1 - 10 of 10 Posts
