Rear Knuckle for ScatPack
2887 9
Hello Community!
I’ve just became a very happy owner of 19 ScatPack and faced an issue with replacement of rear left knuckle :(
How could I know the exact part number of it, that fits my car properly? With Brembo brakes and without drug racing suspension it shows me the part number 68159597AC but some resources says it won’t fit and the part number 4854459AH is needed. So I’m a bit confused what is the correct part number is needed for my car 🤷‍♂️
Attaching photo of my broken knuckle.
Thank you so much in advance.
994645
1 - 10 of 10 Posts
Welcome to Challengertalk ;) Congrats, but sorry with a problem. In searching your 1st number seems correct
994653
The 2nd number seems to be for non Brembos, just regular brakes
994654
See if putting your VIN# in the search box pulls up less choices
994655
Thank you so much for help.
When I specify my car, I have the same parts list as 1st number at your screenshot.
But manager from the moparonlineparts.com asked my VIN-code and sent the pdf file with the original parts for my car.
And it is 4854459AH.
994659
However, in the description of this knuckle is said: Challenger. Charger. Left. Without awd. Rwd, with brembo brakes. With performance brakes.
994660
So I am still confused =)))
And thank you one more time!
Discussion Starter · #5 ·
Yeah, I guess I can't tell from available listings either
That part on the pdf is listed as 4 piston Brembo, and BR4 are 4 piston Brembos
It does show as fitting 2019 Scat Pack
well, then I’ll try 4854459AH and if it doesn’t suites... I’ll try another one :))
thank you for help 👍
Discussion Starter · #7 ·
Look for a part number on your broken one
I though about it, but if I disassemble a knuckle I couldn’t assemble it back because it’s almost totally broken and hold only with saint spirit‘s power 😂 And I can’t leave it unmovable for a long time, my guys refuse to leave it in the center of their service 🤷‍♂️
Ya thats not good. Looks like sway bar mount busted off. Look on ebay. The brake mount is the big difference between the two spindles. Anything with the rear brembos will fit it. Challenger,charger and 300. That lower is a pain in the ass to change. Cut the bolt off and replace it with a new one from dodge. Reverse the way the bolt is installed.
Auto part Engine
Auto part Engine Automotive engine part Wheel
1 - 10 of 10 Posts
