1 - 3 of 3 Posts
aFe Power Momentum GT "Limited Edition" Pro Dry S Cold Air Intake 2011-2019 392/6.4L Challenger/Charger/300
Order --> http://www.speedlogixstore.com/product-p/51-72203-r.htm
  • Dyno-Proven Gains up to +16 HP & +15 Lbs. x Ft. TQ
  • Outflows Factory Intake by 18%
  • Computer-Designed Roto-Molded Red Intake Tube
  • High Quality One-Piece Roto-Molded Red Sealed Housing with Air Inlet
  • Built-In Sight Window Provides Easy Inspection of Filter Without Disassembly
  • Unique (Patent Pending) Filter-to-Housing Interface for Easy Installation
  • Washable and Reusable Pro DRY S Air Filter for Maximum Convenience
  • No Cutting or Drilling for Faster Installation
Unique One-Piece Housing w/ Sight Window:
The one-piece sealed housing is used to eliminate the use of multiple components and ensure the coolest air intake charge available. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of cross-linked polyethylene red. It accommodates the "Hellcat" headlight air inlet for 2015-2019 Dodge Challenger models only (Requires scoop P/N: 54-72203-S).
Roto-Molded Tube:
This system uses a computer designed, dyno-tuned, roto-molded red intake tube to achieve maximum power gains while maintaining a perfect fit. A billet aluminum fitting is mounted on the tube to provide a perfect connection for the temperature sensor.
Large 3-Layer Performance Air Filter:
This Momentum GT intake system was designed around the largest filter possible to allow maximum performance and filtration. This cone filter has a massive oval flange and is 9" tall inverted top Pro DRY S filter media. The Pro DRY S performance air filter features three layers of progressive finer porosity synthetic media providing maximum convenience with 100% polyurethane frame for long life and multiple cleaning cycles.
Premium Hardware:
Premium stainless steel T-bolt clamps and a reinforced silicone hump coupling are used for strength and durability while also providing the most secure installation available. Momentum intakes are designed with fewer parts for a quick and simple installation.
Fitment Note:
This item will not fit Challenger or Charger models equipped with the Shaker hood, or Chrysler 300 models equipped with factory HID headlights.
Emissions Disclaimer:
This intake system is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles.
1 - 3 of 3 Posts
