1 - 19 of 19 Posts
2019 Hellcat Red Eye Widebody
All,
There are a lot of exhaust threads, but I didn't see on about this minor thing I've noticed with my 2019 Hellcat Red Eye.
I noticed it right away. It's not getting worse. After shutting off the engine a little black water drips from the left cylinder exhaust pipe. There is a joint between exhaust pipes where this occurs, with a circular band around the aft pipe that is used to tighten it around the front pipe.
This circular tightening band is a little further aft than the one for the right exhaust, and that is probably why it is allowing water to drip. If water can drip (this is a low point in the pipe) of course gas can escape too, but it probably isn't much.
Anyone ever seen this on a challenger? I'll get it fixed - either myself by loosening the band and moving it forward and retightening it - or have the dealership do it in the spring under warranty. Car is in the garage for the winter.
Best,
Finface
2 things
Either the clamp is loose
Or there is a minor hole/scrape causing the moisture to seep.
Either way, itll only bug you if you look at it
I have a 5.7 and just installed 392 exhaust manifold and midpipes. I welded a vbands in between the mids and catback (for ease of removal/install) and noticed last night that water vapor was leaking after i stop for fuel. I going to leave it alone for now since the shorty install was a pain:)
yeah i think OP want to see the condensation on the tip of the exhaust and not on the midpipe transition. i dont smell any exhaust gas on mine inside the cabin so ill leave it alone for now.
All good answers. So I went out there to the shop where the car is up on a four post lift and after staring at the offending exhaust pipe joint decided I'd fix it. Now, understand, this is brave territory for me because my brain housing group did not receive early training in fixing things of a mechanical nature. I'm more of the "that isn't working, or looking, right" type who can then describe the problem - this is part of my history in life and part of flying airplanes for a living. My hat is always off to the people who fix things - who dare to go where I will not in disassembling things.
But this didn't look too tough. There is a clamp and a nut. Got the ol' monkey wrench out and loosened the clamp. Couldn't move it forward to marry it up with the other one, so I banged on it with a rubber mallet.
That's when the transmission fell out. Nah! Just kidding. But I couldn't move the clamp. It appears to be glued, or welded at the top. I gave it a few good whacks to no avail.
So I retightened it - almost as hard as I could with the wrench - and if that didn't fix it...I'll just enjoy the black spot as landoawd and other posters suggest!
It's normal, nothing to fix.
2019 Hellcat Redeye in white knuckle with silver stripes
It's very common and those black spots it leaves on the garage floor are known as "cat piss" lol!
All,
Best,
Finface
I have the same problem on my 2019 redeye. I called the dealership and the service guy told me that there is a weep hole on the resonator to allow black water to leak all over our driveways. I was beginning to think I had a exhaust leak. Mine also seems to only be coming from the driver side.
2014 SRT 8
It will rust out the exhaust if it DOES NOT LEAK...………...
Seriously? Why would you call them for this? IT'S NORMAL.....
2014 SRT 8
Not true 304, its crappy RUSTS 409 stainless steel. HENCE the drain holes.
Been studying holes since 1983, so a HOLE EXPERT !!!!!
Well the owner of the dealership called me and said it wasn't normal. He even said he has never heard of the problem. He asked me to bring it in and he wants to replace the resonator. I'm not a exhaust expert and I've never had a car that spits out water this bad.
2014 SRT 8
GO get them TIGER !!!!
1 - 19 of 19 Posts
