What diameter and offset should I get to replace the mid-mufflers on a 2016 Challenger RT Shaker A8? Searched the forum and did not see this information, my apologies if I overlooked it.
JS
Those are resonators, the mufflers are at the back. If you want it QUIET, like stock (inside the car) get a Flowmaster Force II cat-back. If you remove the resonators, you just get drone inside the car. If you don't mind a little more interior sound then get the Flowmaster American Thunder system. The great thing with the cat-backs is that you can install them yourselves and save labor cost.
I thought they were all technically resonators. However, I already removed the rear. I am still looking for more bark out of her. I was thinking of replacing the mids with Flowmaster Super 10s.
JS
WRONG! The mufflers are in the middle of the car and the resonators are at the rear.
You are correct. They are all resonators.
Remove the mid mufflers and put in dynomax 24250's. Sounds great on a scat pack. Any good muffler shop will make any inlet/outlet work as long as it is larger than the current diameter. These are 3" in and 3" out. I don't know the size of the exhaust on the R/T but the scat pack is 2.75".
Here is a short clip of it on my scat pack.
