So my spoiler is cracked and my replacement came in today, is it 2 screws and adhesive underneath? Cars a 2012 if that matters
Yep 2 outside bolts and like 2 or 3 pcs of dbl stick tape. Waxed dental floss works good to cut threw the tape
Since it's a 2012 why isn't it being replaced under warranty? :confused:
Cracked due to neighbor pushing on it(got stuck when it was snowy out)
The glue is like cement if it is cold!
If it is cold where your at, then also use a heat gun and get the glue warmed up because it will take you a long time to unglue it when it is hard as a rock.
Ah, gotcha! That sucks. :(
If you use the dental floss trick, watch out for the pins between the adhesive strips. You won't be able to just go straight across and will either need to lift the spoiler or feed the floss under the spoiler.
