Originally this had an AFR Shaker. The shaker setup was starting to crack so I decided to try something new. Enjoy the pics.
Automotive tire Suspension part Suspension Cylinder Gas
Metal Steel Brass Circle Aluminium
Machine Cookware and bakeware Synthetic rubber Transmission part Rotor
Metal Circle Space Gas Machine
Automotive exterior Light Metal Automotive lighting Space
Metal Steel Silver Kitchen appliance accessory Aluminium
Automotive lighting Headlamp Automotive exterior Automotive parking light Light
Tire Motor vehicle Wheel Automotive tire Automotive design
do you have the AFR part that mounts on top of the intake manifold? and the piece that connects to the Trottle Body?
Yes, but the throttle body connector does not have the air sensor.
won't the stock one work? Don't get me wrong I love what you did but don't you have to remove the air cleaner to check your oil? Just thinking of a way you can get that set up in the opening of your hood, that's all.
Discussion Starter · #5 ·
I just have to remove the air scoop to check the oil. Takes about a minute, no biggie. I did try to come up with a center design but could not make it work.
