Hello all,
I just got my vehicle yesterday, I love it. But I encountered an issue The back up camera is not functioning, and then I had someone stand behind and the reverse light is also not working. 2015 Scat pack, Used. Any advise.
I'd suspect the reverse switch (mounted on tranny case for 6 speed) is at fault.
On the automatic, the shifter probably triggers the Canbus on what gear (Reverse is selected)
since there wasn't an indication of which transmission on the subject vehicle, I've mentioned both. The 6-speed has a physical reverse switch - located on pass side of case.
I've attached an example of the Tremec TR6060:
My backup camera occasionally does not work on my 15 Scat Pack 8 speed.. If I turn off the car and restart it's always working again. Looks kinda stupid doing that fix when you're backing out of a spot in a busy area, in a $40K car tho...
Your cars do have warranties, you know. :) Let the dealer figure it out.
Hi Tetralin,
Is this something you're able to duplicate to show to the dealership for diagnosis?
Kori
Dodge Social Care Specialist
Hi Tetralin,
Kori
It only happens once every couple of months or so. So I doubt it.
