Hello Everyone,
I have been unsuccessfully wiring a backup camera for Challenger 2010 model. It only works when I press the brake pedal while in reverse. The only wires I can find are the following.
White with yellow stripe - No power
White with green stripe - Works only pressing the brake pedal.
White with purple stripe - Works only pressing he brake pedal.
Have anyone been successfully wiring a backup camera on this model? Any suggestions?
Thanks!
Jose
White with Light green stripe is back up.
White with dark green is left brake/stop.
White with yellow stripe is right brake/stop.
White with violet stripe is tail light.
Sketch187, when I used a Peak wireless camera I tapped into the reverse light wiring in the trunk lid. Had to remove the liner for access, It worked OK but I eventually went with an RBZ and Lockpick with a license light mounted camera. Still using it...
