My 2011 Challenger SE right turn signal is blinking fast. The front and rear bulbs is fine. I want to replace the fuse first to check if it fixes the problem. If not, I will replace bulb.
Can someone please tell me the location number of the fuse for the turn signal? The manual is not clear about the location number.
Thank you!
Check all of the bulbs front, back, both sides, parking and brake! One of them is burnt.
Reactions: 73RallyeJA5
Usually a bulb either bad, or going bad.
There are 2 bulbs on the rear for each side, so they both must work.
I'm taking a shot in the dark here, but do you have sequential turn signals on the back?
