This is a comparison of the best TT dyno results I had before the install, and the first pull I have tried afterwards.
For some reason the HP drops after 5k so I have a little toying to do. Obviously if it would have kept climbing like the older log did I would have significantly higher peak numbers.
Check my signature for the mods, the only difference between the two were the LT's and the custom tune.
Edit: People seem to take this chart as as loss to low end. The reason it doesnt show gains till 3k is due to the different times I laid into the throttle. The car launches harder than it ever has.
