1 - 12 of 12 Posts
RT Classic Hood Scoop Shaking/Flexing
I've only had the car for a week now and have noticed that the hood scoops shake/vibrate when I'm on the highway. There isn't a sound associated when this happens, I just see the sheet metal of the scoops flexing up and down a little.
I'm assuming since the scoops are functional, the air flow (at higher speeds) is what's creating the shaking.
Not sure if this is normal. Just wanted to confirm that with you guys.
Thanks.
I have never noticed and shaking in either of my classics.
Thanks whylee.
Wonder if I need to bring it up to the dealer?
I did a little research and I believe this is called "hood flexing". Getting a little concerned now.
Thanks whylee.
I get the "hood flexing" going through the blow dryers at the touchless car wash........................but not going down the road/interstate.
I get some hood flexing as well, it's not so much the hood itself I see moving but the reflections off the hood that "bounce" around that I notice. Mainly see it going ~70mph or so.
That's exactly what I'm noticing when I hit the 70s. The fact that it's been windy as hell in Mass has exaggerated the movement when I'm driving against the wind.
Appreciate the feedback guys!
Mine does it all day on the highway ... since the hood is aluminum and the part where the hood is thin (and likely stamped) it is just flexing and vibrating like a cheap cookie sheet.
Now the hood on my 2011 Ram 1500 seems like its going to fly open when its windy, its scary how much that hood shakes and bounces.
I had scoops rattlin.
The rubber things weren't pulled all the way through , tugged and they sorta locked in place.
1 - 12 of 12 Posts
