1 - 20 of 21 Posts
Tell me what you think!!! Before and after shots....
Thanks for looking!!!
Ray
They are ST Coil-overs that I bought during the Black Friday Sale... They ride good and really drop the height quite a bit. Time will tell but it appears to be worth the money for coil-overs. I also has rear solid cradle bushings and front/rear sway bars installed while the coil-overs were going in.
Effing sweet bro
Looks great. I would love to drop mine like that. But I'd never be able to get out of my own driveway.
Looks good. Did you have do camber kits?
Thanks..I am going to have to install camber kit because the camber is out on the rear. Looking into that now...
Effing sweet bro
Appreciate it!!!
Thanks..This is the first one that I have lowered like this so hopefully all parts stay intact...:icon_lol:
Looks outstandly (if that's a word) fast! What about the wheels and tires you have. What size Boss's? What off-set? What size Motivo's? Looking to do the same for mine. Thanks for any imformation.
The rear looks lower than the front, I personally prefer the opposite, slight rake to the front. Looks great though, major difference,! :)
Discussion Starter #15
Thanks... I have a staggered set=up with 20x8.5 front (14mm offset) and 20x10 rear (20mm offset). Tires are factory size and you could go wider in the rear with 20x10 set-up.
Hope this helps!!
Discussion Starter #16
Appreciate it... I am still fine tuning the height... I am driving for about a week to let it all settle and I will remeasure and make final adjustments.
Looks good. I'd get the alignment sorted and be careful driving around and parking.
Discussion Starter #19
Sooooo much better. Just an FYI, it sits about like mine and I don't have a camber kit. 6K miles and so far no uneven tire wear.
Thanks... Any idea what your rear camber is at? I am right at -3 Deg....
Discussion Starter #20
Thanks... So far even with my slight slope in the drive way it's been good... Hopefully I can keep it that way.
1 - 20 of 21 Posts
