Could someone please tell me how to remove the stock rear spoiler on a RT.
Looking at it , it appears there are just 2 bolts at either end that need to be undone. Is that it or is it more involved?
Thanks in advance.
bolts and double sided tape. might be easier to pick up a trunk lid from an SE if you are trying to eliminate the spoiler completely
Just trying to replace it with a Carbon by Design spoiler. Thanks for the heads up on the 3M tape. That's going to make the removal "interesting" to say the least.
Fishing line under the spoiler will help cut the tape. Just be easy with it.
I see your location.....it helps if your garage is heated LOL The two sided tape is easier to remove if it is warmed up...hit it with a hair drier as you slide the fishing line underneath. Post pics when you're done.
