2013 Challenger RT
Is there supposed to be a big gap between the front splitter (68109837) port and port on the splash shield (68060070) going to the wheel well?
I don't see any fillers on part lists, but the big gap seems really odd. I can see the power steering pump.
2018 Billet SXT Plus
Google part numbers 68109838AA, and 68109839AA and take a look at them.
These are both air dam close out panels, and may be what you are looking for.
2013 Challenger RT
@UPNATM 18 thanks for the reply. Those are the close out panels to fill the opening on the wheel well side at fenders. I failed to get those and now they are ordered. The gap I was referring to is looking into the air splitter air port to brakes from the front of the vehicle. I'm thinking this is just the way it is supposed to be. Everything else has lined up perfectly with matching holes. I'm figuring once I fasten the wheel well shields in place, it will be dark in the ports and it will be unnoticeable.
Ah gotcha, ok, take a look at these two numbers, 68086604AA, and 68086605AA.
Those are the intake ducts, on the air dam, left and right.
2013 Challenger RT
Discussion Starter · #5 ·
@UPNATM 18 you are awesome. I believe that is exactly what I need. Wish I would have known this. Didn't do enough research. Thought all I needed was the splitter and splash shield. Thanks so much!
Reactions: UPNATM 18
