Hi
Have to pass this along. Washed the car and went to a ride. After that, noticed rust stain from center cap of my front wheel. Removed the wheel and found a water build up in the spindle hub and caused the metal to rust. The hub is a cup. Cleaned the area with a cone brush on a drill, use brake clean, then primed and painted the hub. Used regular paint, didn't see a need for hi temp stuff.
Hope this helps.
Hope this helps.
