The first video you'll see the car bog a bit...that was becasue I didn't get into the 2 step soon enough and didn;t have enough boost. The 2nd video the car hooked and If I remember that was an 11.48 run. If you listen you will hear me getting out of the throttle, I did that because the car was creeping to over 9psi of boost and I would have blown the tires off...I left with roughly 6#s of boost and forgot to speed shift the 1-2 shift, you'll see the cars nose dip, I speed shifted the 3-4 and ran it out the backdoor to get the E.T. 2 passes later I ran an 11.44 and the passs after that was an 11.37
