1 - 20 of 21 Posts
2020 Challeger Scat Pack 6M Frostbite
I recently bought a 2020 Challenger Scat Pack. I wanted to install a cold air intake, but after receiving it I realized I can't install it. The Scat Pack has one center hood scoop, and on each side of that are small openings, to allow engine heat to escape. One of these is directly over the air box, meaning that the CAI filter would be exposed to the elements. Even washing the car would get the filter wet. Does anyone have any idea on how one could install a CAI on a Scat? Is there some way to fabricate a cover for the filter? Just curious if anyone has run into this problem. Thanks in advance for any suggestions.
2020 Challenger R/T Scat Pak
You can have a cone filter (upper air box lid), and a Hellcat lower airbox, and a headlight ram tube, and have it waterproof, and fed from the center scoop on the Scat Pack.
This should answer most all of your questions: Mopar T/A air intake on Scat Pack widebody thoughts
That being said, the stock air box is a CAI, just not an open element cone filter. Check your air temps on the Performance pages on your car and you will see.
DeWFPo
2018 Hellcat. 2017 Scatpack.
OEM hellcat lower air box, matted to your existing top lid.
OEM hellcat air tube, connecting the open the drivers headlight (if not already) best bang for the buck.
Return the CAI. Do a HC lower mod, as mentioned. Neither will give you any HP, but the HC lower mod will lower the IAT. The stock setup is pretty good from the factory.
Here's a video with the parts list to do the HC lower mod.
Reactions: WVPawPaw
Reactions: WVPawPaw
Your car was built with factory CAI. What are you trying to achieve?
I have added the Hellcat Headlamp Intake Tube and MOPAR CAI intake to my 2020 SP WB (SRT Hood) and she typically runs 5 degrees above ambient on my IAT.
This morning it was 30 degrees ambient, and on the highway (70 mph) my IAT was 33 degrees.
Just monitored IAT vs. ambient air tempeture of my 2020 Scat Padk. The IAT was soon after engine start 4 degrees over ambient. After running some errands snd driving on surface streets it was 10F to 12F over ambient.
I have to note this is with the coolant temperature running at 200F or a bit higher. Going to be hard to lower IAT when the intake system is "bathed" with 200F+ hot air from the radiator.
As I have noted warmer intake air promotes better combustion and thus better fuel economy. Cleaner combustion means less engine deposists and reduced oil contamination. All good things.
Buy lottery tickets. You will have the same success but the potential payoff is better.
Discussion Starter · #10 ·
yes, I know. I have the hellcat lower, tube and filter on mine too. Same results as you.
it’s cool but it isn’t adding any power.
Wow... You honestly believe that a motor (combustion cycle) that is taking in 45 degree ambient air isn't making more power than a motor (combustion cycle) that is taking in 165 degree ambient air?
None. I have the same setup.
It adds "noise" outside of the vehicle. If you stand near the drivers side heat extractor where the filter is, you can hear the air velocity through the throttle body/ intake system.
Neither by buddy or myself have heard any difference. It was one of the things I checked after install. If there is a difference it's very minute.
Reactions: WVPawPaw
That is completely irrelevant to my post. You are suggesting that the factory setup runs way above ambient, which it doesn't.
DeWFPo
I'm the one that started that thread and did end up installing the kit. It works rather well. That being said the most I got out of it is 2 things. A little better throttle response. Before I installed it there was an ever so slight hesitation when giving it gas. After installing it that is now gone. The other thing is the engine is now cleaner withe the scoop being functional. I like it but would never buy it for the prices i see online.
Agreed.
The stock 2020 R/T SP WB intake system does not include the front ram air duct from the headlamp, and does not include the open top box to pull ambient air from the drivers side hood heat extractor. The stock set-up will run 70 degrees above ambient.
You still believe that dropping the IAT to 5 degrees ambient isn't making more power than an IAT 70 degrees above ambient.
The stock system does run warmer but I have only seen 70 degrees above sitting in traffic. The hellcat lower box dropped that only by a couple of degrees but when moving the system recovered quicker. The T/A intake is about the same but it improved throttle response for me. Only very slightly but enough I could notice it. It probably recovers the fastest due to both the headlight opening and the hood scoop being functional. On the highway intake temp stays 2 To 3 degrees above ambient outside temp.
1 - 20 of 21 Posts
