I am very possibly buying this car or a Ss Camaro 1le this year and I am trying to get a honest picture of what maintenance cost will be with the widebody:
- I am trying to get an insurance quote from my current company
- I know that premium fuel needs to be factored in
- I will have to shop for tires to see what they will cost me
- what do oil changes cost? What about other fluid changes?
- labor and parts for rotors and pads when they need to be changed?
- labor and parts for shock replacements?
- any other maintenance costs I am missing?
Thanks.
Get the insurance quote. But God help you if you get a ticket or two or worse.
Due to a flat tire, just replaced two rear tires on my Hellcat. $600. If you want more precise numbers you'll have to get the tire info from a representative car and search online for the tire and how much it costs (and know that tire prices can and will go up over time) and what a dealer (or tire store which I very very seldom use unless absolutely necessary) will charge you to mount/balance the tire. You have to factor in the possibility a flat tire can require you replace both tires on the axle because of the too large a difference in the new tire's diameter vs. the worn tire.
While I don't recall seeing anything in my HC manual regarding this another car maker stated a 30% difference in tread depth between tires on the same axle required both tires be replaced. When I had the car in the SA advised me both tires should be replaced. If there wasn't a 30% difference in tread depth it was going to be close. And with 707hp on tap no way I want to compromise on tires. So I agreed.
And in one case I had a flat tire on a car, my Porsche Turbo, and while a dealer had tires the replacement tire would not be the same tire brand on the car. Porsche does not support mixing tires so I had all 4 tires replaced at a cost of (probably) $1250. I will probably follow this mixing tires thing with my Hellcat.
Oil/filter services for my Hellcat have ranged from free to nearly $140. I suspect going forward the $140 number will be closer to what I pay. And this can only go up.
I have not had any other fluids replaced. With previous cars for one particular car the cost to replace the 5-speed manual transmission/diff fluid was the least expensive service. The labor was just 0.3 hours. The fluid cost around $40/quart and required just over 2 quarts but once in a while the dealer would give me a discount on the fluid. One time when the dealer had some fluid left over from warranty work I got the fluid for $5/quart!
With my Hellcat I have not come across any reports of what it cost to get a fluid service with the A8 transmission. Diff fluid changes have been discussed but I don't recall the price.
While I have the brake fluid flushed/bled every once in a while with my other cars, and I can't recall the cost, I have not had this done yet with my HC. I don't think it will be that much. Maybe 1 to 1.5 hours labor and fluid.
With other cars, my Porsche cars, brakes ran around $1000/axle. Just had the rear brakes done on my Mini JCW. Nearly $500 for new pads, new sensors, some other hardware, but *not* rotors and no brake fluid flush/bleed. With new rotors and a brake fluid flush/bleed the cost would be $1000 or pretty darn close. I don't know about the Scat Pack brakes but the front brakes of the Hellcat alone I believe run in the $2000 area. There may be suitable/acceptable and less expensive aftermarket brake hardware but I have not had any reason to look into this yet.
Have driven from 28K miles to 317K miles on the shocks the cars came with and never had to replace any shocks/struts. But with one car I had to have the CV boots replaced when these developed cracks due to age/exposure. At around 260K miles. Tech removed the shafts, cleaned the bearings and inspected them. They were ok so a repack and new boots and back into the car they went. The cost I'm sure was over $1000 but new half shafts cost $900/each plus labor.
Earlier this same car had a rear wheel bearing go bad (at around 80K miles). $300+ to replace. The other 3 bearings and the replacement bearing were fine when I sold the car at 317K miles.
If you drive the car enough, keep it long enough, budget for not only oil and oil filter, but engine air filter, cabin air filter, possibly fuel filter. Plugs will need to be replaced at some point.
O2 sensors will at some point be needed. I have managed anywhere from 90K miles to 130K miles on O2 sensors. Never had to replace coils -- due to any engine issues -- but on a whim I replaced coils on one engine at around 140K miles and the engine ran better afterwards.
I like to replace the coolant every 4 years which helps prolong water pump life and hose life. While I have had to replace a water pump or two over the years never had a radiator hose need replacement.
Depending upon your circumstances you can (possibly) do some if not all of the above. I could but I have not the place or the time to work on my cars. But in the past I have done oil/filter services, brakes, brake flushes. The transmission/diff fluid service I let the dealer handle. Manual transmission fluid is stinky/nasty stuff. But I have done water pumps, plugs, even (years ago) a clutch (actually a clutch in conjunction with an engine rebuild), fuel pump. Coolant drains/refills. Wheel bearings. All filters. No starters. Alternators. No heating/AC issues. No drive train issues.
Doing the work yourself -- provided you can do it right and if you don't think you can you shouldn't attempt the work -- can cut the cost of the services/repairs mentioned above by roughly half. 'course, there is your time. The time you spend working on the car is time you can't spend on other things, time you can't spend with the family. And I have found it really helps to have a 2nd/back up vehicle to use while my primary vehicle is down. Sometimes a problem can arise that can't be taken care of in a hour or two after work or on a weekend.
