Yes, is that a bad idea
No, just usually folks replace the entire catback. Are you thinking changing the X-pipe to a different X-pipe will give you an improvement in sound? I can hear a difference between X and H pipe but would think the sound difference between one X pipe over another X pipe would be pretty hard to distinguish.
Anyways, you should not have a problem as long as the Scavenger X-pipe is stated as fitting to OEM exhaust systems otherwise you will need a shop to piece it together.
