1 - 10 of 10 Posts
I've had my White 392 since the end of Feb, but I am just now detailing it with Zanio. I noticed yesterday a scratch about 3 inches long on the truck. Is this something I address at a dealership (I purchased the car 2 hours from where I live), or do I try and fill it with scratch X?
Not sure once you leave dealer they will address anything. I would still try though. I had some small ones on mine not deep and used a tad of rubbing compound and scatch remover..then ZANIO and all is good cant even tell where it was now.
Unless you point cosmetic stuff out at delivery...forget dealer. Just get 3M Rubbing compound for light color cars.
Discussion Starter · #5 ·
Tried Scratch X already, and while this has worked in the past on a few scratches, it did not solve this one particular scratch.. Will rubbing compound work by hand, or should I use an orbital buffer?
3M RC & elbow grease.
My painter has told me to run my fingernail over the scratch, that if my fingernail hangs up when you go over the scratch it will need to be painted.
And yeah, you can try the dealer but chances are very very slim. Most will say that it happneed after the lot, which heck it could have. Nnever know what happens when you go into a store or something, but you may find one dealer who wants to earn your business so they take care of it. Those are few and far between though.
It depends.
If it is deep, nothing short of repainting will do.
If it is really shallow, rubbing compound, scratch-x and the like may answer the need.
If it is moderately deep, judicious application of 2000-3000 grit wet or dry,
followed by rubbing compound, scratch-x and another finer polish then wax.
NOT a good process for the faint of heart or uninitiated novice.
I've had good results using a small square of fresh and worn 2000 Grit
water/detail spray (rub very lightly), polishing compound > scratch X > Colorback > Zymol > wax
Check out Junkman2000 videos on youtube
Google 'paint repair' and learn as much as you can.
1 - 10 of 10 Posts
