1 - 3 of 3 Posts
When removing the front seats,which bolts do you remove?The bolts with the 15mm head or 10 mm?
Not the 10mm. 2010 and older use a combination of torx head and 15 mm bolts, all thru the top except front passenger side, bolts go in from the front (horizontal). 2011 and up go in thru the top, I think they are all torx head. The newer seats from '11 up use different spacing, brackets for mounting.
Thanks for the info. I got them out.
1 - 3 of 3 Posts
