1 - 11 of 11 Posts
2016 Challenger SXT
Hi forum,
I want to add a security system to my car but I don't want or need another fob. Is there an alarm that you are using that interfaces with the keyfob for the car? Thanks in advance for any advice and/or suggestions.
I can’t see an aftermarket alarm system working with the current FOB, but if you install an aftermarket alarm, you may not need the OE FOB. I mean, what would it be used for?
2016 Challenger SXT
I will still need the OE fob to start the car. Unless, I get and alarm with remote start, door lock actuators, etc.
Forgot about the starting, yeah I guess that’s kinda important...
IDK man, I’d be very surprised if you can find a way to make an aftermarket alarm work without spending an arm and a leg...but what do I know, I forgot about the FOB‘s role in starting the car! ?
Hi forum,
Maybe add the factory one if you don't have it?
2014 Challenger SRT 8
Hi forum,
Alarms do nothing, still can steal it if they want it bad enough.
Most kits end up hurting the factory wiring causing issues down the road.
I just pull the fuel pump relay, and block the car in if I leave it sit in the yard for months on end
GPS tracker would be a good idea, but do u really want it back ??? never seen a good thief drive nice and easy till U find it....…………..
I have a Ravelco antit-theft device on my 2009 SRT. It is a proven system that has been around since 1976. Highly recommended.
It uses a unique removable 16-pin male connector that completes all the electronic connections. Each plug is individually coded, there are more than 100,000 combinations and no master plugs. Unless the plug is inserted, you cannot start the vehicle even with the key fob. A concealed armored steel cable protects the circuits from the Ravelco base. There are no exposed wires, all wires are the same color, and all connections are made in and through the factory wire harness. A properly installed Ravelco is virtually impossible to detect and extremely time consuming to trace, even for factory trained technicians.
Check out their website.
Not sold yet, my luck they tow it and torch it...………….
Sight says about $650 installed...………...still on the fence
I have a Viper Alarm system. It has a shock sensor capability. So if they break the glass or try to steal the wheels it will go off. You could arm and disarm with the factory keyfob but if you want the 2 way function on the Viper remote (up to 1000 feet) you need to bring that along. I don't bother with it since I have a dashcam and wifi that will alert me if there is motion or impact detected. Then I could view my phone to verify.
Read Only
I could be wrong here, but I think the Challenger has a built-in alarm system already. Try to enter the car without your FOB- use the metal key instead. I tried this and the car alarm went off, even though I don't have any sort of aftermarket or added system
I know this is late but thought it was unusual, went I went today to get the Compustar ProT13 as we’re going over the features he mentions a Keywrap. When I questioned what that was he explains that I either carry two fobs or they hide one in the dash “keywrap”.
1 - 11 of 11 Posts
