1 - 3 of 3 Posts
Hey guys. Just bought a Trinity. I have wired up a Autometer A/f and plugged it into the Trinity. How are you guys that are doing this setting up the tuner to read it like a A/f meter. The gauge specs show it to run from 0 to 4 volts. I have the gauge in the Tuner reading voltage from 0 to 4 but I would like it to show a/f like the Autometer. Thanks for the help.
http://www.dragtimes
when setting up the trinity analog input, it should prompt you what the upper and lower parameters are. On my AFX, 0V = 9 a/f and 5 V = 16 a/f. Don't put the voltages in ( 0 or 4), put in the values that come with your WB.
Your wb should have a chart that at 0v = X a/F (lower parameter) and 5v = Y a/f (upper parameter). Put the a/f values in, not the voltage and you should be good to go.
I also named my analog input 1 A/F so you can pid it when logging.
1 - 3 of 3 Posts
