1 - 3 of 3 Posts
Anyone planning on upgrading the stock CAI on their Shaker? Would the long tube CAI be worth going to with the Shaker?
Thanks
If you're talking about the 2014 shaker, you will probably not be able to adapt another brand or type of CAI due to the way the shaker air inlet goes to the back of the MOPAR cai box. You are stuck with what you have. You may be able to change the filter to another brand with a similar dimension inlet.
Well the only thing you can really do to improve it would be the lower baffle delete and switch the tubes over to a carbon fiber to battle the heat soak which I think will increase drastically with the shaker.
1 - 3 of 3 Posts
