1 - 16 of 16 Posts
2016 Challenger R/T Shaker
So, I have a '16 R/T Shaker
I bout the S Mount Catch Can from Speedlogix
I went to I stall it and noticed my air box extends across the front over the radiator hose.
Im confused about how to install the catch can with the air box in the way.
Am I missing something obvious? Anyone have pictures of their install?
Also, why is the long air box there? Does it increase flow between the filter and throttle body?
Photo attached.
That’s interesting my shaker doesn’t have that extra box. It’s a 392 so I guess there is a difference. You might need a different CAI.
On a 392.
Vehicle Car Auto part Engine City car
2010 R/T Classic 6M
That extra box is a silencer or something like that. All aftermarket CAI delete it and that's why the intake is more audible
Reactions: ApexDestroyer
I think you can get just the intake pipe that is in this kit.
Auto part
Discussion Starter · #6 ·
That makes sense. How can I delete it without buying a whole intake kit?
Found it. I think this is what you need. Steve White can set you up.
Product Text Font Pipe
Discussion Starter · #9 ·
$210 is a little high. If anyone finds an abs one or a cheaper one, I'd greatly appreciate it.
Too bad I can't just cut off the extra piece and cover the hole
2012 Dodge Challenger R/T Classic
That silencer can get cut off, and the hole can be covered with a rubber plumbing cap with a hose clamp—if you are wanting to do it on the cheap. You can also fender mount the catch can instead.
I believe the same Charger non silencer tube that non shaker 5.7 owners use will also fit
If get from Steve White, use discount code CHA1. I'd confirm fitment with them as well
Feel free to call us 561-687-3712 if you have any further questions about your catch can set up.
Our "S" mount catch can only works if you do not have the stock CAI, which is stated in the drop down option :)
- Alexis
Attached is my shaker with the intake tube installed. Have not put the catch can on yet, the car has been in storage.
1004190
2017 T/A 5.7 A8 front and rear strut braces frame connectors
I used the charger intake tube or you can mount it on the passenger side fender there is a spot for the can.that thing that’s on the air tube is a silencer.i buy all my parts from Luke at steve white motors
Moroso makes a nice catch can and it’s got a drain valve on the bottom of it
1 - 16 of 16 Posts
