1 - 4 of 4 Posts
2015 Challenger SRT 392
So I just noticed my shark fin antenna is crooked.
Is it adjustable?
Sent from my SM-N986U1 using Tapatalk
There is very little adjustment available. If you can't grab it and move it from the top, you will need to get under the headliner and loosen the bolt.
And when I say "very little", I'm saying little to none. You have the clearance difference between the hole in the roof and matching mount on the bottom of the shark fin.
2019 Scat Pack triple nickel 6 speed manual.
Super easy to fix...pull down on the headliner in the middle of the rear window...that will release a couple clips that hold it up enough to get a scocket (8mm I think) to the single nut that holds the shark fin in place. Loosen it a little get it where you want it and relighted. Easy peasy.....I had to take mine completely off on my 2019 to reseat the shark fin back on its base.
1 - 4 of 4 Posts
