I have noticed a few times, when the temperatures are cold (20's to 40's), and while the car has yet to reach operating temperature (i always remote start for no less than 2+ minutes) my transmission at times, 3rd to 4th gear, does a quick hesitation (with a slight rpm bump). almost sounds like a slip at shift. This is only a one time event while cold and does not repeat itself during the drive. Has anyone had a similar experience. No code has registered.
during cold warm up driving, its normal for the automatic to delay upshifts - this helps get the cats up to operating temp faster by holding revs higher.
Reactions: USRWDV8
It's normal for an automatic to do that when it's cold. You being from Texas wouldn't know that ;) My truck shifts extremely sluggish when it gets to around 10 or less degrees because of my deep transmission pan. The fluid has to get warm before it operates normally.
Its not higher rpm Its like it shifts to 4th too soon and slips a little. Mine has done it since day one. I usually auto stick for a few minutes so i can have the rpm around 2500 before i shift to 4th.
What you could also feel is the torque converter clutch engaging / dis-engaging.
From 3rd gear on up (light loads) the TCC locks up...when there's more load, it will unlock (higher rpm) and if there's more load/throttle you'll then get a downshift.
I can feather the throttle on my 'Benz (same A5 trans) and get the TCC to unlock when I want a bit more acceleration w/o triggering an outright downshift.
