1 - 16 of 16 Posts
I recently purchased a used 2017 Dodge Challenger R/T with manual transmission. I have searched this forum as well as the internet regarding the following issue but I cannot find an answer. When I am aggressively going through the gears, the transmission seems to flip into neutral at high rpm but the engine maintains its high rpm. The transmission is still in gear. I know that rpm limits can be set on a Challenger. I thought the Challenger would restrict gas into the motor if the rpm limits were exceeded. Like I said, the motor maintains a high rpm. The car drives nicely under normal conditions and this issue only occurs when I punch it. Any information would be helpful and I apologize if this topic is covered under a different title.
It sounds like you're describing it bouncing off the rev-limiter...if so, the behavior is "expected', if not unpleasant.
You can change the RPM at which the rev-limiter is set, but the behavior will remain and occur at the newly set RPM. At least that's how I understand it work. If I'm incorrect, hopefully someone will chime in and correct me.
yes there are tuners who can/will do this, however this is really ill advised.
Dodge set the RPM limits & revlimiter protection for very good reason, in doing so, they provided a slight cushion built in, in the unlikely event of an over-rev situation. tuners that raise/manipulate the RPM, are exploiting that cushion, but its you that will be picking up parts off the road. Be happy there is a rev limiter.
Reactions: PlumCrazy16
While more RPMs will usually equal more HP at any given point in a gear, there is a school of thought that more is not necessarily better when it comes to the 5.7L operating at the upper limits of any given gear. I forget the exact numbers, but to paraphrase, the argument is that pushing a stock 5.7L past the factory configured redline can be done, but doing it would not reduce ETs or yield anything beneficial in terms of power output/acceleration down the road.
As I recall, the 5.7L (with stock cam, etc.) hits its max torque output/HP at well below the redline (5800 RPM?). So while it doesn't hit the redline/rev limiter until somewhere in the low 6000s, it's power output is falling off by that point, and thus pushing it even further toward 7000 RPM before shifting gears would only mean further reducing the relative power output with respects to how much you could be putting out (if the gear had been shifted and the engine were in a higher gear and back into its power band).
I don't know, I don't engage in timed contests of speed like drag racing or anything, so the minutia of this argument didn't interest me enough to further investigate how true it might be. Nevertheless, it certainly sounds plausible enough that I"d want to know about it if I were trying to squeeze out some extra tenths of a second every other weekend at the track...
Hi Mr_Redlegs,
I do apologize for the trouble you are experiencing with your Challenger R/T. If you are not able to remedy this concern with the advice provided here, I kindly recommend connecting with your local Jeep dealer. If you are in need of any assistance with that process, our team is available via private message.
Rob
DodgeCares
I have experienced the same rev-limiter issues and I have to tell you that I am very glad to have it. Have punched a couple of rods thru my hoods in the past (fortunately a long time ago) on the track and it sucks like Hemi4us said to be the one to have to pick up your engine parts while you pride and joy is on the hook. If you're having a hard time getting your timing down, maybe think about investing in a Tazer and activate the shift light feature, it might be worth the $275 it costs as opposed to a 10K motor job or at least hard wire in a shift light? Anyway, good luck with it.
‘15 R/T 6M STP
If you're having a hard time getting your timing down, maybe think about investing in a Tazer and activate the shift light feature...
Pretty sure the shift light feature isn't available for R/T's, only SP and up.
‘15 R/T 6M STP
I don't have the shift light option in my 2019 T/A 392 M6, so I installed a Holley Sniper OBD-II Shift Light.
That's pretty cool, I like it.
In theory, you should be able to turn on the shift light option using a Tazer or AlphaOBD. Not sure if the issue is missing code in the PCM or the 160 mph speedo IP, but the 3.6/5.7 cars get no results when turning it on.
‘15 R/T 6M STP
Tazer says it activates the shift light for 2015-2016 Challengers. Not sure about other years.
Don't find anything specific about it anymore, but the earlier literature for the Tazer said 6.4 only for the shift light.
I guess it depends on what version we are looking at. I will defer to you! I would rather spend 130 on a shift light anyway because there is so much stuff that the Tazer doesn't do for the R/T's I guess it's really not worth the cost.
2019 Challenger Scat Pack T/A 392 M6 Go Mango
I thought about getting a Tazer to activate the factory shift light, but I opted for the Holley one since I could mount it in my line of sight instead of having it show in the instrument cluster. I like being able to set individual shift points for each gear, set a launch rpm and adjust the brightness.
2013 RT Classic
I offer this just as an FYI as I have a different car but,
With my auto, if I put it in manual shift it will still upshift but just at the rev limiter. This is higher than even the performance upshift in straight auto. The RPM is right at 6200 and is a little higher than stock though the short block is stock 5.7 so you should be fine at that or below RPM. We did minor adjustment to the trans when we did the custom engine tune at the install of the supercharger.
1 - 16 of 16 Posts
