2016 R/T Scat Pack
I hear some rattles up front hitting bumps. At 131k I suppose it's time for shocks, struts, etc... I wanted the Mopar P5155435AD upgrade kit but it's on forever backorder. Suggestions please.
2016 R/T Scat Pack
Discussion Starter #2
Anyone???
Oh man, I waited months for that kit a couple years ago when I ordered it for my '10. Then when it finally showed up, it had the front shocks for a 2011-up so they didn't fit to my lower control arms. I had to order 2 front shocks for a 2010 SRT to complete the kit.
I wonder if it would be easier to order each part individually?
2016 R/T Scat Pack
From what I’ve read all you need is a longer bolt and a couple washers to make the fronts work. There is a Mopar kit with just the shocks and struts but it’s near the same price...
I've run Bilsteins on my cars for 30+ years - still my go-to brand and they last a long time and over their service life keep their efficiency.
If you have an R/T, the Bilsteins will be much firmer than the Sachs units it was equipped with. Much tighter valving characteristics.
Im with Hal on this one. You can always change the lower shock bushings to the 11 and up to accommodate the newer front shock.
I would change the whole lower control arm then. It's been a while since I looked at it but as I remember, the 2011-up bushing has a longer bolt sleeve, is larger in diameter, and it is actually lower on the control arm. Putting the new style (Taller) shock on the old control arm with a higher mount location might slightly raise the front end. That's if you get it to work with washers and a longer bolt.
This is the pic I took when I encountered this. I thought about using washers and a longer bolt, but it just didn't seem proper to me. Went with the 2010 SRT Bilsteins for the front and completed the kit. The car handled awesome after.
