1 - 20 of 29 Posts
i ordered my new rims and tires for my 10 R/T and the company sent me 275/45/R20 and they dont fit...WTF any suggestion to avoid taking the tires off and sending them back and waiting for new ones?
no the width is fine its the height of the tire, had it on the lift and put one on and it was already rubbing the end of the bolt above it. would a spacer bring it out enough so it wouldnt rub that?
Mine came with 45X20 from the factory and they look fine and don't rub.
TVJP 245/45R20 BSW AS Performance Tires
well i dont know what the problem is maybe it is then, im just going by what the people at the shop said, i didnt actually see it but they said they height of the tire was the issue. so now im looking for a solution so i dont have to go thru the hassle of sending all of it back and wait longer. so 275/45/20 should fit is what your saying?
I don't know if it will fit or not, but 275/45/20 is a taller tire than 245/45/20. The 45 means the height is 45% of the width.
yea i know what the measurements mean my stock tire is 245/45/20. what im wanting to know is there anyway to make the 275/45 work?
Your right it 1" biger diameter but it looks like I have more room than that.
SpecificationSidewallRadiusDiameterCircumferenceRevolutionsSpeedometerOdometerDifference275/45-204.9"14.9"29.7"93.4"678/mi60MPH10000miN/A245/45-204.3"14.3"28.7"90.1"703/mi62MPH10371mi-3.6%
it will fit on the back but up front is the only problem
I have 275/40 R20's on the front of mine (much bigger int he rear) with no issues however that is on aftermarket rims so I suspect that if you put these on the stock rims the offset isn't right to prevent the rubbing in which case spacers may help. Or it could just be that you needed 40's instead of 45's.....
With new tires I don't think I'ld chance it. If they say they don't fit I'ld send them back and if you don't have a preditor your speedometer will be off.
Discussion Starter #13
yea im thinkin i need a 275/40 and thats what i thought was coming, the bag with all my lug nuts in it even says 275/40/20 so they just messed up the tire they had the right size in mind
That would be pretty close 1/10 of 1% speedometer change.
SpecificationSidewallRadiusDiameterCircumferenceRevolutionsSpeedometerOdometerDifference245/45-204.3"14.3"28.7"90.1"703/mi60MPH10000miN/A275/40-204.3"14.3"28.7"90.0"704/mi60MPH10007mi-0.1%
Discussion Starter #16
20in aftermarket rims all around, the tires i ordered were 275/40/20
Discussion Starter #20
yea im going to get my predator soon so il be fine untill then but the major thing right now is, is there a way to get these tires to fit. will spacers make them fit on the front
1 - 20 of 29 Posts
