1 - 20 of 21 Posts
Fits 2015+ Challenger
Up for sale is a DODGE CHALLENGER HELLCAT REPLACEMENT/ CONVERSION AIR INTAKE OEM MOPAR
Part # 68175164AC 68172459AA 68207918AB
The set was on the car for about 1,000 miles;
Available for Pickup from SF Bay Area
Discussion Starter #2
Brand new barely used!
Would it fit an 08 srt8?
Rab - just a quick note for you. The '08 - '10 cars have a power steering reservoir adjacent to the coolant tank...
The airbox is shaped differently to accommodate those components. The '11+ air boxes are a different shape (and larger) since there wasn't a p/s reservoir and the coolant tank shape was changed.
and the '15+ headlights are different from the '08 - '14 design. The inner "headlight" on the earlier design has a socket / reflector setup where the newer design has an LED ring that functions as turn signal and has the pass-through design for Air Catcher induction system.
Is there a write up for installing this on a 16 SXT Plus?
Where's the top of the box!?
The TB and air tube duct for a Hellcat is larger than what the other engines use - so you utilize your existing V6 / 5.7 / 6.4 top of airbox to the HC base.
Ah, thank you!
Is there a write-up, video, or a walkthrough anywhere?
Ah, thank you!
One of the vendors commented on why they didn't include the top of the airbox in the 'kit' for that reason - plus the IAT sensor mounts in a different place for the Hellcat setup. [the HC models use a MAF sensor in-line on the air tube that other models don't]
Ah, thank you!
It is very easy to do. If you have a phillips head screw driver, and are mechanically inclined, you can do it.
Interested, PM sent.
Discussion Starter #17
Really? I paid $160 for the set.
Sent from my iPhone using Tapatalk Pro
Can get them online for $95.
Hell, I should probably just ask my parts guy. I get it at cost... wtf was I thinkin!?
Discussion Starter #19
Not with the hellcat filter.
Discussion Starter #20
Sold
1 - 20 of 21 Posts
