1 - 15 of 15 Posts
Looking into purchasing a nice used R/T, most likely a 6 spd and have a few questions, I have been reading a lot on this board but just need some clarification. First was the STP option available in 09? Do all 6 spd cars have the limited slip dif with 3.90 gearing? Silly question but do stick cars come with cruise? Also I saw in a picture one car had some skinny chrome trim around the tail lights, was that an option or is it an aftermarket add-on? More questions to follow but I have my mind pretty well made up my mind I want a R/T with a 6 speed just looking for the exact right car. Thanks!
Discussion Starter #2
Also exactly what all do you get with the STP option?
No STP in 09. But back in 09 manual transmissions were optional. They called the option Track pack.
No, base 18inch rims get 3.73, 20in rim cars get the 3.92 ratio.
Yes...
Those are stick on, aftermarket.
Also what was the horsepower rated for 09? That was the first year with the EAGLE heads correct?
If it has 3.92 gears it is a limited slip. I believe all 5.7 Challengers have the Eagle heads.
Many threads on the differences and I tried to compile a list so if anything is wrong hopefully somebody will correct, but basically STP has lower ride height (2012-up), stiffer springs, yellow Bilstein shocks (early Bilsteins were black), quicker steering ratio, higher performance brake pads (thicker for heat resistance?), Goodyear F1's (on some models may order All Seasons Goodyear RSA instead), on 2011-up automatics the ability to turn the ESP traction and stability control OFF, I think a larger rear sway bar (20mm vs 16mm?), hydraulic belt driven power steering pump (early models only, 2014 pump is electric, not sure when this changed).
The STP option requires 20 inch wheels and much to some owner's dismay, does not include the Anti-Spin rear axle. All manual transmission Challengers include AS whether STP or not, but with the automatic, you must order AS even on the STP. The STP package is included as standard equipment on only two Challenger models, the Black Top and the Shaker, it must be ordered and is extra cost on all other R/T models.
Reactions: DJ Hemi
Yeah, it's the T-Rex Polished Tail Light Trim available from sponsor CARID. Thinking about it myself...
Also, do the 6 speed manual trans cars have a digital gear position indication on the instruments?
I asked the same question when I test drove mine, my first 6-speed. Trust me, it doesn't take long to know instinctively which gear it's in. Easiest manual shift I've ever driven.
Reactions: DJ Hemi
Yeah, this is an awesome 6 speed trans, but I have to remember to pull the shift lever to the left when going from 1st to 2nd gear. The ratio's are so tight, I've gone from 1'st to 4th twice since I've had my Blacktop RT. The last standard I drove was a 1970's Datsun 4 speed Z-car. lol
...but I have to remember to pull the shift lever to the left when going from 1st to 2nd gear. The ratio's are so tight, I've gone from 1'st to 4th twice since I've had my Blacktop RT.
This might be the factory "skip-shift" kicking in. It is designed to save fuel by forcing a 1-4 shift under certain conditions. If you are just cruising around this is where it will get you, if you get on it a little in first you'll never see it. There are kits to disable it but I'm leaving mine alone and drive around it, it has only bit me once so far.
Dang I didn't even know that! That's just when it happens when I'm just cruising around! I could swear that I'm going to 2nd but it goes to 4th! I even fought with it a few times. lol
Good thing it's easily defeated. Look for a skip shift eliminator from one of our vendors.
Justin
Justin
Great advice right there. The damn thing will kick in when you don't expect it, and it could ruin (or just embarrass you) your day.
I wish there was a reminder to tell me to shift to 6th gear. I don't drive on the highway too often and when I do, I keep forgetting to shift to 6th because 70-80 is no problem for 5th.
1 - 15 of 15 Posts
