1 - 15 of 15 Posts
‘74 Duster 360 4M
Anyone willing or able to post their spring and suspension package options from a '15 Scat Pack and/or SRT? Trying to compare what my R/T STP came with.
This is what I got from my Build Sheet:
SBPP Performance Steering
SDEP Sport Suspension
SHFS Rear Stabilizer Bar
ZAVP Spring - Left Rear
ZGFP Spring - Left Front
ZNVP Spring - Right Rear
ZVFP Spring - Right Front
P/N breakdowns from my list are:
Rear bar 68184226AA
Rear Springs 5181369AC
Front Bar 4782544AC
Front Springs 5181609AB
Just curious how those part numbers compare to what a SP/SRT would have come with, but the info I have makes it hard to figure it out without the option codes from the Build Sheet as the catalog lists like 10 possible springs that all fit everything from an SXT to a HC but are specific to an option code. Front sway bars are easy as there are only 2 (Touring and Performance), while the rear is a little harder to figure out.
Thanks!
‘74 Duster 360 4M
Discussion Starter #2
Just to be clear, this info comes from a Build Sheet, not an Equipment List. I've seen several Equipment Lists posted and called a "Build Sheet" but they aren't the same. The Equipment List only shows the option, but no codes. The Dodge app will give an Equipment List, but I had to contact Dodge and ask for the Build Sheet.
Here's mine:
EZC- 5.7L V8 HEMI VVT Engine
DEC- 6-Speed Manual TREMEC Transmission
PSC- Billet Clear Coat
*D5 Torque Cloth Sport Seat
-XG Black/Tungsten
APAS Monotone Paint
AWD Super Track Pak
RA2S Uconnect 3 with 5" Display
RCGS 6 Speakers
WSQP 20X8.0 Aluminum Hyperblack Wheels
Full build sheet:
-XG Black/Tungsten
APAS Monotone Paint
AWD Super Track Pak
BABS 160 Amp Alternator
BCNS 730 Amp Maintenance Free Battery
BGEP Brake Assist
BGFP Anti-Lock Brakes
BHCS Rain Brake Support
BHDS Ready Alert Braking
BHES Knock Back Mitigation
BNBS Electronic Stability Control
BNGS Hill Start Assist
BNPS All Speed Traction Control
BPTS Hydraulic Assist Brake Booster
BR6P High Performance Brakes
BTBP All Vehicles w/ABS Brakes
CBDS Active Head Restraints
CFNS Rear 60/40 Folding Seat
CF4S Child Seat Upper Tether Anchorages
CG3S Advanced Multistage Front Air Bags
CG6S Center Rear 3-Point Seat Belt
CHKS Base Headliner Module
CJ1S Supplemental Frt Seat Side Air Bags
CJ2S Supp. Side Curtain Frt/Rr Air Bags
CKDS Floor Carpet
CKMS Trunk Carpet Kit
CLZS Luxury Front & Rear Floor Mats
CM6S Floor Console w/Armrest
CSNP Rr Armrest w/Cupholder Seat
CSVP Interior Assist Handles
CVKS Cell Phone Storage
CVWP Leather Wrapped Shift Knob (Manual)
CWPS Illuminated Cupholders
CXCP All Vehicles with Cloth Seats
DEC 6-Speed Manual TREMEC Transmission
DMTP 3.90 Rear Axle Ratio
DR4P 230MM Rear Axle
DSAP Anti-Spin Differential Rear Axle
EZC 5.7L V8 HEMI VVT Engine
GAMS Solar Control Glass
GBCS Front & Rear Solar Control Glass
GFAS Rear Window Defroster
GNCS Sun Visors w/Illum Vanity Mirrors
GN5S RR View Auto Dim Mirror w/Microphone
GTNS Power Mirrors, Fold-Away
GXDS Remote Proximity Keyless Entry
GXRS Keyless Entry
GXXS Sentry Key Theft Deterrent System
GX4P Keyless Go
HAFS Air Cond ATC w/Dual Zone Control
JAAS Instrument Panel
JA6S Electroluminescent Instr Cluster
JBKS Instr. Panel Accent Color Bezel
JCCS 160 MPH Primary Speedometer
JFAS Compass Gauge
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JKWS 12V Center Console Power Outlet
JKYS Power Accessory Delay
JLPP GPS Antenna Input
JPCS Power Trunklid Release
JPHS Speed Sensitive Power Locks
JPSS Power 6-Way Driver Seat
JPUS Power 4-Way Driver Lumbar Adjust
JPYS Pwr Windows, Front 1-Touch Down
LACP Illuminated Entry
LAHS Outside Temp Display in Odometer
LAXS Front Passenger Seat Belt Alert
LAYS LED Taillamps
LBCS Glove Box Lamp
LBGP Front Reading/Map Lamps
LBWS Rear Courtesy Lamps
LDCS Trunk Lamp
LEPP Body Color Exterior Mirrors
LMBS Halogen Headlamps
LMGS Automatic Headlamps
LMNS Daytime Running Lamps, Park/Turn
LNJP Fog Lamps
LNKS Illuminated Door Pull Handles
LPSS CHMSL Lamp
LSAS Security Alarm
MDAP Front License Plate Bracket
MFHS Satin Chrome Grille
MGHS Grille Badge - Challenger
MLAS Body Color Fascias
MNKS Body Color Door Handles
MV4P R/T Badge
MW5P Fender/Hood Badge - Hemi
MXXP Rear Bodycolor Spoiler
NAS 50 State Emissions
NERP Dual Rear Exhaust w/Bright Tips
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
NLQS 18.5 Gallon Fuel Tank
NMCS Heavy Duty Engine Cooling
PSC Billet Clear Coat
QSCS Billet Clear Coat
RAAC All Radio Equipped Vehicles
RCGS 6 Speakers
RDLS Integrated Window Antenna
RDZS Steering Wheel Mounted Audio Ctrls
RFUP 5.0" Touchscreen Display
RHKP Harman Radio Manufacturer
RSFP Media Hub (SD, USB, Aux Ports)
R02P All VP2 Radios
SCVS Leather Steering Wheel
SUDS Tilt/Telescope Steering Column
TBCP Compact Spare Tire
TVHP 245/45ZR20 BSW Perf Tires
TZAP Goodyear Brand Tires
WLZC All Aluminum Wheels
XAAP ParkSense Rear Park Assist System
XACP ParkView Rear Back-up Camera
XARP Bright Pedals
XA8S Non Adjustable Pedals
XFCS R1234YF A/C Refrigerant
XGAP Front/Rear Climate Control Outlets
XGMS Tire Pressure Monitoring Display
XG8S Sport Mode
XJES Bright Fuel Filler Door
XJGS Non Locking Fuel Filler Cap
XKDS 'Why Buy' Label
XLNS English/USA Language
XRBP Integrated Voice Command w/Bluetooth
XSAS Dark Brushed II Interior Accents
XSLS Brake/Park Interlock
XXTP Humidity Sensor
X8NS Alumn Front Suspension Parts Module
X8US Rear Fascias Parts Module
X8WS Front Fascias Parts Module
X8XS Brake & Knuckle Parts Module
X81S Instrument Panel Parts Module
X84S Front Suspension Parts Module
X85S Rear Suspension Parts Module
X87S Power Train Parts Module
X88S Tire & Wheel Parts Module
X89S Front Suspension Damper Parts Module
X91S Rear Suspension Damper Parts Module
YAAS Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGFA 8 Additional Gallons of Gas
Z1EP GVW Rating - 5300#
0ADA FAM: LA TRACKING:LASHAKERAD MY:2015
1AAS U.S. Dealer Retail
170S Zone 70-Phoenix Arizona
2DBA Customer Preferred Package 2DB
22B R/T - 22B
4EX Sales Tracking
5I8S Left Hand Drive (LHD)
5LDS 2015 Vehicle Specifications
5N6 Easy Order
5ZSS Two Door
5ZVS Rear Wheel Drive (RWD)
57VS LA/6120 Vehicle Family
594S Vehicle Order Tracking
6USS U.S. Specifications Label
648S Washington Ship to State Code
875P United States Region Group
894P NAFTA Region
948S Washington Sold to State Code
We've got the same front springs but rears are different.
ZJXP - left rear
ZXXP - right rear
I'll check on the rest.
2016 SRT 392
Reactions: DionR
‘74 Duster 360 4M
ZJXP - left rear
ZXXP - right rear
2016 SRT 392
Thanks!
Perhaps due to yours having an auto as opposed to my manual?
Thanks!
Don't know the difference in the rear springs. I did check the springs on an M6 SRT and they show the same as my A8.
My rear sway bar is the same as yours, front and rear suspension and damper parts modules the same and so is the brake and knuckle which I thought was odd because of the Brembos.
My steering shows as SBLS electric power steering.
Suspension is SDXS high performance suspension.
Reactions: DionR
ZDG - Left Front Spring
ZDX - Left Rear Spring
ZSG - Right Front Spring
ZSX - Right Rear Spring
2015 Scat
Reactions: DionR
‘74 Duster 360 4M
How did you check the springs on a M6?
My next guess would be that the extra 110 HP causes Mopar to use a different rear spring in the 6.4 cars. If so, then the SP would have different rear springs than I do as well.
Careful there, that is almost heresy. Sounds like you are almost saying that I could bolt on Brembo's without swapping knuckles. :surprise:
Based on my limited ability to look at the parts catalog, looks like there are only 2 knuckles used for MY'15 and later. One without performance brakes and one with. Based on this and your findings that my R/T and your SRT use the same knuckle, maybe BR6 brake cars wouldn't need a knuckle swap to add Brembo's. But it is confusing because I never was able to find brake part numbers where I was looking that included Brembo's, only 1 and 2 piston calipers. So it might be murky enough that I am wrong.
Read a thread on a guy swapping the 6 piston SRT Brembo's onto his SP and he mentioned getting a part printout based on VIN to compare what his car came with versus an HC. Wish there was a way to do that in this case, too.
Maybe because you have more modes?
BTW, because my car came without the 8.4 Uconnect, I don't have the Performance Pages and can't change my steering other than what the Sport Mode button might do. So it could be that in the case of my car, maybe my steering was downgraded due to the lack of the big screen?
Gotta believe your selectable ride settings changes the code, but just a guess.
‘74 Duster 360 4M
2015 Scat
Thanks!
Any chance you could post your suspension code?
I found an M6 online and ran the build sheet.
Yes, Scat Pack has different springs, as posted above.
That Kuckle code must mean something else as the SXT also has the same code.
Could be, not sure.
Agree.
Thanks!
SDX High Peform Suspension
SHF Rear Stabilizer Bar
X84 Front Suspension Parts Module
X85 Rear Suspension Parts Module
Reactions: DionR
‘74 Duster 360 4M
You must have privileges I don't have. I would have done the same, but all I can get is the equipment list via the Dodge website without going through the customer service and I'm pretty sure they would ignore my request if I didn't own the car. :)
Can you do a part list by VIN as well?
Maybe the SXT has STP?
I only found 2 part numbers for knuckles, one with performance suspension and one without. Makes sense that "performance suspension" included Brembo's, but the description says "Challenger. Charger. 300. Left. With police vehicle. With perf. Suspension. With performance brakes. Without awd, with brembo brakes."
Knuckle
I know there is a difference somewhere in the suspension since the Mopar "big brake kit" (Charger Pursuit BR9 brakes) requires that the car come with the BR6 brakes, leading me to believe that a non STP Challenger has a different knuckle from one with STP.
I got my build sheet from Dodge for my car and also have a sub to compnine where I can get other sheets although sometimes there are errors with them.
No but would love to have part number access!
That SXT I looked at did not have STP, the knuckles are definitely different for Brembo, all 4 of them! The online parts checkers make it tough, don't think the police 14.5 inch rotor cars use the Brembo knuckles but don't know any other differences, need part numbers I guess rather than just codes.
Reactions: DionR
Where are you guys getting your build sheets? Finding them in the car, like the old days?
Not a single sheet like the old days, there were 4 or 5 sheets used in the building of you car and often they are left in the car. Problem is the dealer usually throws these away during their PDI except for the one in the trunk or in the spare tire well because I guess they never look in there like they're supposed to. Anyway, highly doubt you'll find a sheet or two hidden anywhere so if you don't have them now they are probably gone.
You can get a simple equipment list online by using this link, just swap the VIN in the link with yours and use all capital letters.
http://www.dodge.com/webselfservice/BuildSheetServlet?vin=2C3CDZC94HH572376
For the full build sheet with codes send an email to Dodge with your information and last 8 of the VIN. In the comment section just ask for the build sheet, they will email it back to you in a couple days.
https://www.dodge.com/webselfservice/dodge/emailpage.html
‘74 Duster 360 4M
Discussion Starter #15
At this point it's all just idle speculation, anyway. I've only made one payment on the car, so the budget won't support something like a Brembo retrofit (and the associated mega$$$ for WRT's), and who knows what the future holds.
One last comment; it does seem that something changed for MY2015 because when I went looking to see what BBK's were available for my car I found ZERO. Could be that I missed them, but everything I found was for MY2014 and down. Some did say 2008+ but when I dug into it, they didn't fit. Baer's website even says "Vehicles with 2012-2017 Spindles" as you step through the options, but when you get to the brake kit is says 2012-2014. Even the kits for SRT's stopped at MY2014.
Not saying it answers the question, nor that it points to anything, only adding it as curious fact.
Either way, I've had the original question answered. I was curious if the STP package had the same suspension as the SP and/or SRT. Read some comments that they were, and other's that said their SP rode rougher than the R/T w/STP they traded in did. Figured I would look at the hard parts rather than just opinions.
Looks like the answer is "No". Maybe the same front springs and rear sway bars, but even that is a maybe as GregF911 didn't show the same codes for the front springs. Either way, they are a different suspension package.
'Nuff said. :grin2:
1 - 15 of 15 Posts
