What size spare tire did you get if you ordered one for you R/T with 20" wheels/245/45R20 tires??? I forgot to order one.
Thanks!!!
Phantom Black SXT+ 100th Anniversay
Hi, I have those same size tires on my SXT and my spare tire size is145/80/18. Hope this helps you out. B-
Thank You!!! Will this size work with a posi rear end. The spare, T145/80D18, is a little over 1" smaller diameter. Or if you have a rear flat, do you have to do the two tire change thing.
Well keep in mind that this spare tire is only meant to be temporary. And if you have 20 inch rims now this is 2 inches less diameter. I don’t think it will affect the posi if you have to run it on the rear since I’m guessing you’re not going to horse it until you get a replacement tire.
Spare temp only. Yep. I've found that a T155/85r18 spare tire is 28.4" tall that is the same size as the 245/45r20. I like looking for info.
