Hi all,
I wanted to use exactly what Kenne Bell recommended for my application which are (NGK 2309) LFR7AIX-11
The -11 part denotes supplied set @ .039
Without the -11 supplied set @ .031
Obviously all plugs will be checked to confirm accuracy of gap and adjust any variables as required.
Now Kenne Bell say set @ .035
NGK say you can re-gap these plugs max +/- .008 so either plug version can be adjusted to KB's recommendation.
I see KB used to recommend gaps as low as .025 but I assume this has changed with the use of the Iridium plugs.
I note a lot of people seem to end up adjusting to between .026 to .032
Finally the question....I am wondering if I should just install the plugs I have coming after checking they are NGK gapped @ .031 or open them up to .035?
As always opinions/advice/experience appreciated,
Thanks.
Discussion Starter #2
OK no replies..... I have installed @ .031
Hopefully not a bad choice as I am looking forward to not having to re-gap or do a plugs change for a long time.
Phil.
I have no knowledge :) You might tag [email protected] Bell , and see if he might have some answers for you.
Thanks for your suggestion but Kenne Bell can be very regimented with their information and damn near impossible to get a straight answer out of at times. As I said they recommend .035. I was looking for feedback from a section of the forum that indicated that worked well or in fact that the more frequent recommendations of .030 - .032 range was a better option, not confirm KB's recommendation.
As an example I have asked 3 times what the rev limiter is set at in the tune they supply and have been told *OEM 5800 *6500 *Do not know sorry. I guess I will find out at some point if I hit it.
Also in their install instructions for the snout brace they say remove 3 OEM bolts/ install the 4 supplied bolts (and they supplied 4 bolts) show you a picture where 3 bolts go.... there is no 4th bolt hole so you stand there and scratch your head for a minute and wonder should you believe everything they write down let alone say.
Most supercharged cars run between .028 -.032 wider cap has longer hotter spark but people talk about spark blow out. Only thing I have ever seen that done in Is a funny car / top fuel car. I am it could happen but I doubt it
What I have them set at is fine and shouldn't have any issues
Thanks for the input, at least with the hemi we have two per cyl that would have to be blown out.
I run mine at .032. I had some at .028 and seen no difference FYI
Thanks for the info on your experience, I think I am going to be good as gold with them @.031 and 9psi.
