Hello -
Doing my first DIY, installing SPC Upper Control Arms, Hotchkis Swaybar, Speedlogix sway links, ceramic pad swap, and KWv2 shocks. Needless to say, I've got my hands full...So far, I've got the left side torn down, with the SPC UCA in place (not tightened), the passenger side is 50% disassembled, the pads swapped, and the Hotchkis bar in place.
Questions -
Thanks for any pointers!
Questions -
- Is there a trick to getting the rear facing UCA bolts out/in?
- I had a hell of a time getting the drivers side out using a flexy 1/2" ratchet 2 clicks at a time, and am now fighting the passenger side
- My passenger side nut was covered with some rubber tape covering (what's that for?) which I basically tore around the nut, and I just don't have room to get at it with the wrench.
- All the videos I've seen make it look like a piece of cake (while not showing how the was taken out).
- In this job, are the UCA, shock tower, sway bar, etc. all other bolts only snugged, then final torqued after the car is back on the ground?
- Do all nuts get blue loctited?
