1 - 15 of 15 Posts
I just bought a new 2016 R/T Plus that has the Harmon-Kardon audio system in it. That includes two speakers mounted in the trunk space that a spare tire would normally live in. I'm not real comfortable having to rely on a compressor and can of fix-a-flat in the event of a flat tire. Let alone a blowout, I'd really be screwed in that case. So I'm wondering if it's possible to remove those two speakers (I assume they're the sub-woofers) and restore that space to it's original purpose.
FYI - any of the Brembo equipped models don't have spares - if you don't opt for HK audio option, you get the black foam box along with the fix-a-flat and air compressor.
So all those T/A 392s, Scat Packs and SRT models don't have the option of spare tires either.
The well will only hold a compact 18" spare setup - a full size tire won't fit in that well. I had the spare tire / jack option on my '09 R/T...
Removing that module will have a negative effect on the quality of sound your stereo produces. I opted for a full size spare for times when I'm out on the road in the wide open spaces. If I'm around home, I rely on roadside assistance/towing via AAA to deal with a flat via tow to a tire shop. I also carry a tire plug kit with large pliers so I can make a repair that will hold air until I get to a tire shop. I don't want to pump a load of goop into any of my wheels if I can help it.
Yeah, I'd always assumed that a spare would have to be the compact one, and I'm fine with that. I don't even object to having to go out and buy one myself. I just want to know if it's possible to remove those two speakers without completely screwing up the rest of the audio system.
Hmmm. I hadn't thought about plugs. Is that something I can find at the corner auto parts store? And yeah, I suppose if all else fails I can always just pick up a spare, jack and lug wrench and throw them in the trunk. Less room for other stuff, but it's better than having a blowout and no spare out in BFE someplace. I've also thought about getting AAA.
I have the HK system. I love it, but yeah, no spare???
I went on E-Bay and found a dealership selling donut spare tire kits for Chargers at less than $150. So I have a donut, jack, and lug nut wrench in my trunk now. The spare really doesn't take up that much space sitting on top. I guess it all depends on how much you use the trunk. FWIW, lug nut sizes changed in either 2014, or 15. So be aware if you go this route like I did. You don't want the older, smaller lug nut wrench.
Pre '11 the OEM lug nuts are 21mm
'11+ went to 22mm lug nuts as OEM
I got my plug kit at a NAPA auto parts. It is a kit with tough, rubber/tar like impregnated ropes that you force in to a puncture that has been prepared. The kit is self contained with everything needed to install a plug. Does not come with anything to remove the offending screw or nail. That's why I carry large pliers. Only works on relatively small punctures. Tears or splits are not plugable. And of course you'll need something to put air back in the tire.
If you decide to carry a spare, make sure whatever you get clears the brakes on your car. Does your rear have a limited slip differential? That can also complicate things.
2016 Challenger SRT 392
I would love to find a way to either custom mount a full size spare and jack, or remove the speakers and mount those separately making room for a spare.
I would not use the goop either. Actually my emergency pump doesn’t even work!! I went out and bought a better one from Costco to keep in the trunk.
There's a bracket for mounting a full size spare, there's also a seperate rubber piece that covers the area since that stock cover has to be removed. Here's the bracket and cover shown on a police charger and an SRT Challenger with I think the same bracket and full size spare. The HK subs need to be removed and you could use the earlier kicker sub instead.
This is a UAE spec SRT Charger with the bracket and full size spare.
Discussion Starter #13
I went ahead and picked up a plug kit. I may decide later to go ahead and throw a spare and a jack and lug wrench in the trunk. Changing out the sub-woofers is a little more effort than I want to expend, I think I'd rather live with some loss of cargo capacity. The jack and lug wrench might not be a bad thing to have even without a spare - plugging a hole might be a lot easier with the tire off the car, depending on where the hole is.
Discussion Starter #14
Do you happen to recall the name of that dealership? I did some searching on EBay and didn't find that kit. The "Spare Tire Kits" that I did find, turn out to be nothing more than a replacement compressor when you read them (even though the description says it includes a tire, wheel, jack etc., which doesn't appear to be true - the price is way too low to include all that anyway).
This was 4 years ago, so I can't recall the name of the dealership. I only remember that they were in Texas.
1 - 15 of 15 Posts
