Reduced engine temperatures add life to your engine and provide a denser air/fuel mixture which helps produce more horsepower. Consistent control of engine temperature allows an engine to operate at its peak efficiency no matter what the driving conditions. The factory 203 degree thermostat simply cycles open and closed, this reduces cooling efficiency in any engine. With the 180° thermostat you get consistent engine cooling and a precise metering of water throughout the engine. Specifically Designed for the Mopar application
Opening Temperature Rating: 180 degrees
Flow Rating: High-flow
Gasket Included: Yes
Thermostat Material: Stainless steel
Quantity: Sold individually.
Our Speedlogix Adjustable Sway-Bar Link System provides the ability to easily adjust or tune the sway bar as part of the suspension system.
To Order: http://www.speedlogixstore.com/product-p/sx-sbel-set.htm
BENEFITS:
Allows For Fine Tuning of Front Suspension
Stronger Than Factory Endlinks...
If you're looking for stylish aftermarket wheels in matte black or bronze look no further:
To Order: http://www.speedlogixstore.com/category-s/24368.htm
We have a package for all four wheels or you can buy each wheel individually.
Features
Flow Forged Construction
Hub Centric to Charger /...
Speedlogix 2-point Arched Rear Shock Tower - you get the benefits of tightening your rear suspension but you do not lose very much trunk space! Space savings with performance benefits!
To Order: http://www.speedlogixstore.com/product-p/sx-306-5013a.htm
Standard color is black wrinkle powder...
Our aluminum wheel spacers are designed to fit 5x115 bolt pattern.
Set of 2.
1/4" Hub Centric Wheel Spacers
Made in the USA.
In stock now!
To Order: Speedlogix 1/4" Hub Centric Wheel Spacers 5x115 (Set of 2)
If you have any questions please feel free to call us (561) 687-3712 or...
Speedlogix lowering springs give your ride a low, aggressive look, high performance handling and no ride harshness.
Ride Height: Moderate
Lowering Note: 1.25"-1.7" front & 1.25"-1.5" rear
To Order: Speedlogix Lowering Springs 2009-2018 5.7L/6.1L/392/6.4L/6.2L Challenger R/T, SRT, Hellcat...
