If you are looking for a catch can for your HEMI here is another offering from Speedlogix and AAD!
Thanks
Mikey
To Order: Speedlogix AAD Billet Oil Catch CanDesigned by All Angles Design, Speedlogix is the exclusive supplier for the AAD catch can for the Mopar vehicles. Each can comes with the Speedlogix logo laser etched on the bracket and the Speedlogix chevrons << laser etched on the top of the can.
- Patent Pending Twist-Lock can attachment makes it quick and easy to remove the can even in tight quarters. No more risk of cross-threading or over-tightening.
- Dual Inlet/Oulet capability means you can always configure the AOS to suit your CCV plumbing needs.
- Exclusive dual all-metal filtration media lasts forever, cleans without dis-assembly, and removes as much oil as possible without plugging.
- The lid, body, and mount bracket can each be rotated independently to any of 8 positions. This ensures you can get the fittings pointed the right direction in any installation.
- Every hole is sealed with a Buna O-ring and every piece of hardware is stainless steel for maximum corrosion resistance.
Note: this will not fit on vehicles with an EGR.
Thanks
Mikey
