Uneven Tire Wear? Bump Steer with Lowering Springs or Coilovers? If so this Bump Steer Kit available at Speedlogix is the answer!
Correct Your Bumpsteer with this Speedlogix Bumpsteer Kit that features spherical rod-ends with tapered shafts for a hassle-free installation that requires no drilling of the spindle for fit. Recommended for easier alignments and a wider range of adjustments.
Definition: Bumpsteer is a change in toe* angle caused by the suspension moving up or down. Bumpsteer is built into the geometry of the suspension and steering system, and has nothing to do with turning the steering wheel. The effect of bumpsteer is for the wheel to toe-in or toe-out when the suspension moves up or down. This toe change or “steering” occurs any time the suspension moves, whether it is from body roll, brake-dive, or hitting a bump in the road. Bumpsteer is undesirable because the suspension is steering the car instead of the driver.
US Patent Pending
We have two kits available for all Challenger, Charger, Magnum and 300c vehicles.
Click here for more info
2005-2010 Charger, Challenger, 300c, Magnum
Speedlogix Bumpsteer Kit 05-10 Challenger, Charger, 300, Magnum
2011+ Charger/Challenger/300c
Speedlogix Bumpsteer Kit 11-18 Challenger, Charger, 300
We have these in stock here and ready to ship same day!
We have bumpsteer kits in stock!
