1 - 20 of 71 Posts
If you are looking to tighten up your Challengers Suspension these are for you!
These true full-length connectors run the entire length of the floor pan for increased chassis rigidity, better handling and improved ride. We use round chrome-moly tubing and these sub-frame connectors are designed to have no ground clearance issues.
We spent countless hours figuring out where the LX cars could benefit most from chassis stiffening. Here is the end result....Made from 4130 Chrome Moly material this brace is specifically designed for the LC Chassis cars. It ties together the inner/outer frame rails and the rear lower control arm mount. Braces are bare metal but can be powdercoated or painted for a long lasting finish. These Must welded in for installation for maximum benefit from this brace.
These are perfect for serious cars with high horsepower, sticky tires or competition suspension.
* These tuck in very close to the underside of the chassis and hang only as low as the side skirts of the Challenger
Speedlogix Matrix Brace Subframe Connector 08-17 Challenger
Any questions, just let us know!
Mikey
Stiffen your Challenger's suspension with a set of our subframe connectors!
Tie in your Challenger's suspension with a set of our subframe connectors! In stock, everyone :)
Our subframe connectors are in stock for those that want to tie their suspension together!!
Our subframe connectors are a great way to tie your Challenger's suspension together!
Reduce flex and get better handling with our weld in subframe connectors!! :bdaysmile:
Great Chassis mod, stiffens up the entire chassis!
In stock and ready to ship!
Our subframe connectors are a must if you're looking for the best handling out of your Challenger!!
Great mod I love my subframes, they make a huge difference in handling. I am posting this from the road course event I'm at today, so i can assure you they do make a big difference!
1 - 20 of 71 Posts
