SPEEDLOGIX ADJUSTABLE REAR SWAY BAR END LINKS 2005-2018 CHALLENGER/CHARGER/300/MAGNUM
To Order: http://www.speedlogixstore.com/product-p/sx-lxlc-swr-sd.htm
Thanks
Chris
Our adjustable end links directly replace the factory non-adjustable end links. This provides you with ability to adjust the sway bar preload and tune the Rear sway bar. Used for the ultimate in handling setups. These pieces use chrome moly steel adjustment tubes which are lighter and twice as strong as competing designs. Strong reliable ball joint ends allow for greater turning radius than competing setups and do not produce noise making them perfect for street use.
BENEFITS:
Allows For Fine Tuning of Front Suspension
Stronger Than Factory End links
Adjustability of Rear Sway bar for Drag Racing & Road Racing Applications
Chrome Moly Lightweight Adjustment Tube
40% Stronger Balljoint Than Competing End links
Great Upgrade For All Cars Stock or Modified
Comes as a Pair
Thanks
Chris
