Was thinking of getting springs but will the stock struts be good or should I just buy new ones for them. Or do they sell lowering springs with struts already together
Brand new shocks and struts will be fine with lowering springs. if you want the performance matched, then you can get matching dampers. I was going to get the Pro System, but the shop that installed said no need unless I was looking to eek out every ounce of performance. The stock units do a fine job for anything I need.
Look up your car, and then the Pro System
Start Here - Application Look-up | eibach.com/america
PRO-SYSTEM (PRO-KIT Springs & PRO-DAMPER Shocks)*| Eibach Springs
I'll probably replace mine just because it might be time for new ones but I won't get the pro pack just some regular struts and remove the springs that come with it and get the lowering springs if it works out fine
Thank you!
I want new lower Springs after just installing my pro system, let me know which you go with. I'll sell you these when I get them off and put my H&Rs on if you'd like the pro Springs
